meshing on a cluster
Old   January 15, 2010, 04:48
Default meshing on a cluster
Johannes
jopawipr is on a distinguished road
Hey everybody!
Does anybody know how meshing does work on a cluster?
Calculating is no problem, but just meshing?!
Thank you for your help!
Jopawipr
jopawipr is offline   Reply With Quote
Old   January 18, 2010, 14:35
f-w
f-w's Avatar
f-w is on a distinguished road
Meshing is still serial, and not parallel. I haven't tried it yet, but I assume it is done on the controller if you're running in parallel.
f-w is offline   Reply With Quote
Old   January 26, 2010, 10:45
Maddin is on a distinguished road
Some meshing functions can run parallel but not all
Maddin is offline   Reply With Quote
Old   February 12, 2010, 10:33
Default Meshing on a cluster
ttl
Todd
ttl is on a distinguished road
I do this fairly often. It works well if you have a node that has more memory then the rest, which is the case on our clusters. I typically launch a job that only does the meshing and saves the file then I run the job later. I request a node by using a memory request in the job submission script then the queue manager directs the job to the node with more memory. That way if the job crashes half way through you don't have to remesh.
I have run jobs the remesh based on the flow field solution gradients during the solution but this is time consuming and not appropriate for all types of jobs. As others have said meshing is still primarily serial, which is a major weakness of the mesher IMHO.
Todd
ttl is offline   Reply With Quote
Old   February 13, 2010, 05:06
Split the regions and mesh per region, then you can mesh with less memory.
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Meshing Kevin FLUENT 1 June 28, 2004 04:04
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
