February 4, 2010, 08:23 |
Mesh creation Help
Joćo Pinto
Greetings everyone,
I'm posting because I've been trying to recreate a mesh with these kind of features as shown in the first picture, Meaning Polyheadral mesh with prism layers near the top surface on the side surfaces. But what I can't reproduce is the red areas marked in the picture. Can anyone explain me how I can get those perfect rectangles in the both top surface and "inlet" surface? What happens when I try to do using: Polyheadral mesher Prism Layers Mesher Surface Remesher I get the red marked areas some weird polyheadral meshes or at least triangles, which is not what I want. I need those perfect rectangles on the surface. If anyone could please explain me how to do this, I'd greatly appreciate it EDIT: I should mention that I did the geometry in Pro E, saved it in .stp file, and imported it as surface mesh. Much appreciate it. Last edited by joaorp; February 4, 2010 at 12:52. Reason: Adding more information |
February 5, 2010, 03:36 |
meshing
i think u should not use the prism layer meshing option
February 5, 2010, 06:55 |
Joćo Pinto
I've tried not using prism layers, but I won't get the effect I want (meaning the first picture there with the prism layers included).
Is there any program I can use to make once cell thickness meshes? If start ccm doesnt' do it? |
February 11, 2010, 08:43 |
Rep Power: 18 |
Why you don't want this?
February 11, 2010, 16:41 |
Joćo Pinto
I want this, but with prism layers :O because that is really what I require.
February 12, 2010, 04:18 |
Rep Power: 18 |
Then use the remesher to get a good surface mesh and prism layer to get this volume mesh
February 12, 2010, 14:09 |
Joćo Pinto
Will it produce the first picture mesh? I mean, one cell thickness? Because I've never achieved that even using the remesher.
February 13, 2010, 05:00 |
Rep Power: 18 |
The wall layers are prism, this you can change, only when you modify the mesh via custom meshing on the sides (volumetric controls).
Maybe I don't understand what you really want |
February 13, 2010, 05:51 |
Joćo Pinto
I really appreciate your time and help, what I want to do is make a mesh like the first picture (grey one). What I usually end up with is something like the second one. The red part is my main problem. They're not even alike.
February 15, 2010, 07:12 |
Rep Power: 18 |
I think when you try the mesh setting with a simple sample you will understand what happens.
Periodic mesh creation in ICEM | epa | Main CFD Forum | 1 | May 1, 2012 16:24 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
Help needed for airfoil mesh creation using GAMBIT | Alagesanj | FLUENT | 2 | October 20, 2008 11:39 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 12:21 |
General questions on grid-based computing | Adrin Gharakhani | Main CFD Forum | 21 | June 5, 2000 13:47 |
