January 15, 2010, 04:48 |
meshing on a cluster
Johannes
Rep Power: 16 |
Hey everybody!
Does anybody know how meshing does work on a cluster? Calculating is no problem, but just meshing?! Thank you for your help! Jopawipr |
January 18, 2010, 14:35 |
Rep Power: 17 |
Meshing is still serial, and not parallel. I haven't tried it yet, but I assume it is done on the controller if you're running in parallel.
January 26, 2010, 10:45 |
Rep Power: 18 |
Some meshing functions can run parallel but not all
February 12, 2010, 10:33 |
Meshing on a cluster
Todd
Rep Power: 16 |
I do this fairly often. It works well if you have a node that has more memory then the rest, which is the case on our clusters. I typically launch a job that only does the meshing and saves the file then I run the job later. I request a node by using a memory request in the job submission script then the queue manager directs the job to the node with more memory. That way if the job crashes half way through you don't have to remesh. I have run jobs the remesh based on the flow field solution gradients during the solution but this is time consuming and not appropriate for all types of jobs. As others have said meshing is still primarily serial, which is a major weakness of the mesher IMHO. Todd |
February 13, 2010, 05:06 |
Rep Power: 18 |
Split the regions and mesh per region, then you can mesh with less memory.
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 11:03 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Meshing | Kevin | FLUENT | 1 | June 28, 2004 04:04 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
