Failed to Set Up Power on Demand
Old   April 13, 2012, 12:02
Default Failed to Set Up Power on Demand
Naveen
vetnav is on a distinguished road
I have a Power on Demand License. I have installed STAR-CCM+7.02.008 on my laptop (Windows 7 64 bit). I followed the steps to setup power on demand license.
After launching STAR-CCM+, I go to File -> New simulation and select "serial" and under the license "PoD session." I get the following output
Starting local server: starccm+ -server -power -podkey <unset> -licpath 1999@flex.cd-adapco.com
Serial process 3932
STAR-CCM+ Version 7.02.008 (win64/intel11.1)
License version: 10 Oct 2011
Required feature version set to 2012.02 or later
Checking license file: 1999@flex.cd-adapco.com
PoD database message : -20001 FAILED_TOKEN_NOT_RECOGNIZED
Failed to get all licenses needed for this job. Asked for 1 licenses of ccmppower
To me it appears that I am missing the personalized license for my machine. So, I downloaded the lmulti file to get the host id. But, when I run the command lmulti.exe lmhostid I get the following error
'lmulti.exe' is not recognized as an internal or external command, operable program or batch file.
I have contacted the support team but not heard from them, they might be very busy. Could anyone explain me what is wrong.
Thank you
vetnav is offline   Reply With Quote
Old   April 13, 2012, 16:13
TMG
TMG is on a distinguished road
It says -podkey <unset> meaning you have not set your personal key that identifies you uniquely. You have to get the key from the support site and then you have to set the appropriate env variable with that key.
TMG is offline   Reply With Quote
Old   April 13, 2012, 17:49
Naveen
Hi TMG,
Thank you very much for the reply. This is the first time I am trying to work with STAR_CCM+ so I am little confused and frustrated with all these errors.
In my support page, I went to Real Time License but I don't see any podkey. Do I have to create this key? I see an option to create license key under manage keys.
When I try to create it, it asks me things like Alias, valid from, IP address restriction, max hours. I don't how all this works. The document I received from support team does not give any guidelines to create licenses. In the first email I got from the support it said "If this is the first time that your company has been provided with Real time credit, a new token has been automatically generated for you." Is this token same as podkey you were talking about? I can't find any token or podkey.
Thank you
Old   April 13, 2012, 18:13
Naveen
Thanks TMG,
I figured it out. I can use STAR-CCM+ now
Old   April 13, 2012, 20:36
TMG
Glad you figured it out. Don't be afraid to call CD-adapco support if they don't get back to your email quickly enough.
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 08:44
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 04:31
OpenFOAM installation on SUSE92 problems derath OpenFOAM Installation 1 April 3, 2006 06:44
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
