Swapping Geometry
Old   September 30, 2010, 08:12
Default Swapping Geometry
Tim
colorforadollar is on a distinguished road
I think this is a simple problem but I think I'm missing something...
I have a SIM file set up and runs perfectly but I want to change the geometry I'm testing. What is the easiest way to swap out the geometry in a region without creating a new one? How do you guys do it?
colorforadollar is offline   Reply With Quote
Old   September 30, 2010, 13:47
John
nomad is on a distinguished road
If the geometry was imported as a part instead of a region, then you can right click the part, then select 'replace part'.
Else, you can import the new part, and delete the old one.
nomad is offline   Reply With Quote
Old   October 1, 2010, 08:37
Tim
The original surface was imported directly as a boundary as all the tutorials show.
When I import the new geometry as a part, I can't get it to show in any Geometry Scene. When I assign the previous boundary to the surface from the new part, it's ignored and the mesher just meshes the old shape. When I create new boundaries from the new Part surface, it's also just ignored and cannot be displayed either.
I just don't want to have to respecify everything in the volume if I need to do a huge parametric survey of shapes. It can't be this difficult, I must be missing something.
Old   October 2, 2010, 15:27
abdul099 is on a distinguished road
Hi
several annotations to your questions...
You can show parts in a geometry scene, if you coose to show the "Geometry" in the displayer. If you have showed the region before, the displayer will show the volume mesh (or the initial surface if you delete the volume mesh), so you have to switch before you can see the geometry from the imported part.
Any region created from a part is transfered to a "Initial surface" when you initialize the meshing. Before that, you can only see it by switching to geometry in the displayer, like i wrote above.
If you have any importable surface representation, maybe a dbs, stl, igs or something similar, you can right-click on "Representations - Imported Surface", and choose "Replace Surface". I'm not fully sure what will happen to the boundary definitions. But I'm sure, it will not keep your settings if your geometry definition is not similar to the first one.
If you want to run several similar cases, with only slightly changes, another possibility is to write a java macro (or record one and modify it slightly to your requirements). It may be more work at the beginning, but you can just modify some lines to adjust it to another case.
Cheers
abdul099 is offline   Reply With Quote
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
Update Geometry - swapping SolidWorks files sanchezz CFX 7 December 9, 2009 22:18
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
