November 13, 2010, 13:51 |
Macro to export data
Jonny
Rep Power: 16 |
Hello, I am new to Star CCM+ but even newer to Java. I fully appreciate how useful it can be and am starting to try and learn it.
At the moment my general Java knowledge is poor but specific Star CCM+ opperations is non existent. I would like to create a macro that exports some of the solution's Scalar plots plus scalar area averaged values at the last itteration, so the final value of outlet area averaged temperature for example. I would like this data and scalar images exported to an Excel file with the name of the simulation as the name for the excel file. Is this a pretty tricky task to do? Any help would be gratefully appreciated. Thanks a lot. |
January 6, 2011, 16:52 |
Rep Power: 21 |
The easiest way is to record a macro and edit it slightly (e.g. path names...)
You can access report values via a macro with something like AreaAverageReport areaAverageReport_0 = (AreaAverageReport) simulation_0.getReportManager().getReport("Name of report"); areaAverageReport_0.printReport(); I'm not sure wheter it's possible to write an Excel file directly from ccm+, but at least, you can write a .csv-file. It will need just a little knowledge of java programming. Let me know if you still need help. |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
macro for data automatic export | Andrea | CFX | 0 | May 9, 2008 08:09 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
