Mesh quality assesments
Old   November 21, 2011, 00:07
Default Mesh quality assesments
Eran
Surfboy is on a distinguished road
I tried to search in prior questions but surprisingly did not find:
When i build a model, and mesh it, how can i tell if the mesh is good enough?
Assuming i dont want to wait for the run to end and then mesh finer and finer until it seems the change is neglegable.
i am running a flow around a ship.
I know i should check that Y+ is lower then about 100 and courant # is lower then 1. where can i find some reading material about it?...
thanks.
Surfboy is offline   Reply With Quote
Old   November 21, 2011, 03:21
abdul099 is on a distinguished road
There is no general rule how to define a mesh as a "good" mesh. It seems, you have to invest the time and wait for the run to end and refine. Or you need a colleague or somebody else with expertise in simulating ships and give you some hints, but that's hard since there might be some side effects etc. as long as it is no simple reference case like an Ahmed body for external aero.
And especially Y+ can only be plotted when some "realistic" velocity field has established, so for that you need to run it at least once to see about your Y+ values.
abdul099 is offline   Reply With Quote
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
