June 12, 2014, 00:58 |
ECFM 3Z Spark Ignition / Extended Data
Rep Power: 12 |
I'm having the following issue: The pressure rise upon ignition is highly unphysical. It's a partload case with a highly stratified charge. So I tried adding the RKLIMIT value (to limit kernel size) to the extended data segment as recommended by the User Manual, but for some reason star doesn't recognize that value and ignores it.
I added the following to the extended data segment: RKLIMIT 0.001 In the manual it says I'm supposed to add it in the ecfm section, but there is nothing else in there and no specific section (within extended data) for ecfm. Any ideas what's the problem here? I'm working with Star CD 4.18. Thanks for your help! |
June 12, 2014, 04:13 |
Rep Power: 12 |
Update: Some macro obviously overwrote the Extended Data segment, it is working now.
However: It seems like limiting the kernel size to 1mm didn't have any effect at all. I'm trying with 0.6 now (it is initialized with 0.1), but would like to know whether anyone here has any experience and or recommendations for what value should be used. Thank you! |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
[OpenFOAM] saving data in paraview | aylalisa | ParaView | 3 | May 31, 2014 11:38 |
[General] Warping Cells by Vectors? | ronwelty | ParaView | 10 | April 29, 2014 05:52 |
Spark ignition | lost.identity | STAR-CD | 0 | February 4, 2013 08:32 |
spark ignition engine | Hennie van der Westhuizen | Main CFD Forum | 2 | January 15, 2002 11:59 |
