Home > Forums > Software User Forums > Siemens > STAR-CD
Simulating closure of a valve
Old   March 17, 2009, 07:12
Default Simulating closure of a valve
HJ1969 is on a distinguished road
Is there any way to phisically simulate closure of a valve, for ex by changing cell types from fluid to solid during run time..... or by any other way?
HJ1969 is offline   Reply With Quote
Old   March 19, 2009, 05:25
Anton Lyaskin
A_Lyaskin is on a distinguished road
Check Tutorial 13 for the beginning
A_Lyaskin is offline   Reply With Quote
Old   March 19, 2009, 08:02
dear A_Lyaskin, thanks for the reply. I intend to simulate water hammer in a large dia (3200mm) duct due to closure of a butterfly type of valve which is installed downstream of a pump.
will go through the tut. i hope the approach in tut 13 can be applied for my case.
Old   March 19, 2009, 13:27
Anton Lyaskin
You can also check tutorial 11 -probably it'll be even closer to your problem. It would be better to start with 11th then, because it begins the explanation of cell addition/deletion concept.
Simulating the pressure loss of a valve Hartmchr CFX 9 July 4, 2008 02:18
2nd moment closure model Hatef.kh Main CFD Forum 0 December 23, 2007 06:28
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 12:30
turbulence closure models kiran Fidelity CFD 1 February 24, 2006 09:07
3D Second Moment Closure ridwan Main CFD Forum 3 August 20, 2001 03:55
