April 9, 2010, 17:19 |
Subsurface Creation Issue
Stephen
Rep Power: 16 |
I have a high pressure turbine airfoil that I am trying to create a subsurface on. The issue is in the film cooling tubes. These tubes have a diameter of 0.025" and some are at acute angles. The film cooling tubes have the smallest extusion layer 0f 0.004". The issue is that it does create a subsurface but some of the tubes have the correct thickness and some have much thicker layers up to 0.006". Why does proam ignore the value I give for the subsurface depth?
April 9, 2010, 18:36 |
Stephen
Rep Power: 16 |
I believe I found my problem. I failed to mention that I was using the command -march-ramp-angle=5. Default angle is 25. I changed this number to 10 and the subsurface heights on all the tubes are 0.004".
Issue Involving Paraview | MechE | OpenFOAM | 22 | October 31, 2010 08:29 |
Issue regarding creation of Partition file | Jwala.R | OpenFOAM | 0 | July 1, 2009 11:49 |
Memory issue - Suse 10 - Opterons | Andy R | FLUENT | 1 | June 23, 2008 14:44 |
subsurface failed | star-user | Siemens | 4 | April 9, 2008 05:58 |
pro*am issue | carno | Siemens | 3 | October 23, 2003 04:32 |
