Home > Forums > Software User Forums > Siemens > STAR-CD
difference in the trimming and mapping method
Old   April 25, 2011, 03:32
Post difference in the trimming and mapping method
gurumech.pdit@gmail.com
guru is on a distinguished road
hi,
im working in the es-ice and i need to now the difference b/w the trimming and mapping method used in the es-ice.
guru is offline   Reply With Quote
Old   April 25, 2011, 10:48
Pauli
Pauli is on a distinguished road
Been a while since I did any serious es-ice. Here is what I remember.
The trimmer cuts (i.e. trims) a mesh with your surfaces. Typically the method creates polyhedral cells at the trimmed locations. Trimming requires a water tight starting surface.
Mapping takes a pre-defined mesh topology (i.e. the template) & morphs it to fit your surfaces. You define (i.e. map) related surface pairs between your surfaces & the matching template surface. Mapping does not require a water tight starting surface.
Pauli is offline   Reply With Quote
star-cd
Trimming and Mapping Methods with ES-ICE Zancanaro Siemens 0 June 2, 2009 14:16
