Home > Forums > Software User Forums > Siemens > STAR-CD
Fuel film on piston and cylinder
Old   April 18, 2012, 05:47
Default Fuel film on piston and cylinder
Krishna
kri321shna is on a distinguished road
Hello
how to get the fuel film on the piston and cylinder in fuel-air mixing analysis in star cd.
this is how cell data stored
{ CELL DATA
SU "Velocity Component U" m/s
SV "Velocity Component V" m/s
SW "Velocity Component W" m/s
MassFlux "Mass Flux" kg/s
P "Pressure" Pa
PTER "Thermo. Pressure" Pa
TE "Turb Kinetic Energy" m2/s2
ED "Dissipation Rate" m2/s3
VIS "Turbulent Viscosity" Pa s
T "Temperature" K
H "Enthalpy" J/kg
DENS "Density" kg/m3
CP_M "Mean Specific Heat" J/kgK
CP "Specific Heat" J/kgK
COND "Conductivity" W/mK
CONC_001 "C8H18"
CONC_002 "N2"
CONC_003 "O2"
CONC_004 "WFMASS"
CONC_005 "WFTHICK"
CONC_006 "WFTEMP"
CONC_007 "RG"
VOID "Void Fraction"
Thanks in advance.
Regards,
Krishna
kri321shna is offline   Reply With Quote
Old   April 18, 2012, 07:41
Krishna
wall date has saved as attached:
Old   April 18, 2012, 10:56
Pauli
Pauli is on a distinguished road
Assuming you activated the liquid film model & did all the appropriate setup steps. The liquid film information will be stored in the wall data. To get film thickness use the command: getw lfthk.
Pauli is offline   Reply With Quote
Old   April 18, 2012, 23:50
Krishna
Thank you so much for your reply.
i have tried that command getw lfthk,
it is giving this below error:
CREATING WALL BOUNDARY SHELLS
**INTERNAL ERROR - FAILED TO CREATE SHELLS FROM CELL FACE,ITER= 1
ICNEW,ICA,IFACE,ICTDUM=638898 535803 16 139
**ERROR - CREATING BOUNDARY SHELLS
i am following this procedure
1. loading the post date
2. events running
3. storing the time
4. getw lfthk
can you please suggest me.
Thanks in advance.
Old   April 19, 2012, 10:58
Pauli
That sounds like a bug. You should contact cd-adapco support.
Movement of piston in a cylinder with fluent? Whitworth ANSYS 5 March 3, 2015 23:50
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 01:40
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 15:44
cylinder and piston m.shams CFX 2 June 10, 2010 15:21
CFD Work on 4-stroke piston cylinder san FLUENT 0 September 20, 2006 13:27
