February 13, 2015, 10:47 |
CFL_ADAPT: invalid option name
Akm
Dear experts,
I just installed the complete suite of SU2, and downloaded all the test cases. I'm trying to run the airfoil case (i.e. inv_NACA0012.cfg, so I typed (in a new directory called EX1, where this directory contains all the *.cfg and *.su2 files): C:\SU2\EX1\SU2_CFD inv_NACA0012.cfg The execution failed with the following messages: CFL_ADAPT: invalid option name CFL_ADAPT_PARAM: invalid option name MGCYCLE: improper option value for type unsigned short I've tried running other cases and the application gave me the same messages. The path to SU2_CFD has been set correctly. Many thanks in advance, cfd_dude1 |
March 6, 2015, 10:01 |
Ulrich H. Becker
Facing exactly the same problem.
Found this here: http://www.cfd-online.com/Forums/su2...fig-error.html and this does solve the problem, i.e. delete the line or comment out by a leading %. My testcases are from the tgz file in the download area and may be as up to date as it gets. Best, uhb |
June 29, 2015, 01:36 |
cfl_adapt invalid option name error in su2
karthikvatvat
Rep Power: 11 |
Hello CFD Engineers
I have a problem in Running my configuration file, I corrected all input file and other data but still , It is showing error cfl_adapt invalid option name error in su2 Can any one help me how to move on Thank you in advance |
installation, test case |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
