Home > Forums > Software User Forums > SU2 > SU2 Installation
output results are not created in parallel compuations
Old   May 21, 2015, 03:56
Question output results are not created in parallel compuations
dhxlxz is on a distinguished road
Hi,all,
i have tested SU2 2.3.1 in serrial and parallel. when it runs in serrial, the volume data was output as flow.dat, surface_flow.dat, however, when it runs in parallel, no flow.dat, surface_flow.dat were created.
Different test cases, including naca0012, M6 wing, were test, the output results were not genearted.Hence, what is the problem, and can anyone give some suggestions on how to deal with it?
dhxlxz is offline   Reply With Quote
Old   May 26, 2015, 16:39
Thomas D. Economon
economon is on a distinguished road
In order to avoid overheads when running in parallel, we only write restart files during runtime. Output files can then be generated from the restart using SU2_SOL. Please see more information in the documentation here: https://github.com/su2code/SU2/wiki/Post-processing.
Hope this helps,
Tom
economon is offline   Reply With Quote
The results difference between parallel and serial run. Hkp OpenFOAM Running, Solving & CFD 2 April 17, 2014 02:26
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
results with parallel processing Muhammad Shakaib Main CFD Forum 1 December 29, 2005 00:56
CFX-5.7 MPICH Parallel Problem (Output of Results) James Date CFX 7 February 15, 2005 16:03
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
