June 7, 2013, 12:17 |
Should I be using SU2?
Ritwik
Rep Power: 12 |
I am trying to figure out flow dynamics inside a closed cylinder with an inlet and outlet pipe attached to it. The boundaries are inlet, outlet (at one end of each pipe) and wall (pipe walls, cylinder walls). There is no sufficiently far boundary that can be defined as a free-stream boundary.
As far as I can tell (from the tutorials), free-stream boundaries are an essential part of the problem definition/setup (consistent with the code being developed for Aeronautics etc). Am I correct in this conclusion? If yes, is there a work around I could use to adapt SU2 for my needs? If no, is there some advice/documentation/an example cfg file I could use? Also, I am working at a pressure range ~ 1e2-1e3 Pa range - Reynolds number and Knudsen number do put me in a viscous flow regime. Any caveats regarding SU2 use. Thanks. Ritwik |
June 13, 2013, 18:50 |
#2 | |
Francisco Palacios
Rep Power: 15 |
Despite there is not a particular tutorial about this, SU2 counts on a Riemann invariant based implementation of the inflow and outflow boundary conditions that are very appropriate in the kind of internal flows that you are describing. I think that SU2 fits very well in your application. Futhermore, this post http://www.cfd-online.com/Forums/su2...osing-su2.html could be useful for you in order to take a final decision. Best, Francisco |
FSI with SU2 | akail | SU2 | 4 | February 18, 2015 13:12 |
earnestly request for a standard configuration file template for very SU2 new version | Tommy Chen | SU2 | 1 | June 13, 2013 18:07 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
New SU2 Forum Opened at CFD Online | pete | Site News & Announcements | 0 | January 5, 2013 17:59 |
Stanford University Unstructured (SU2) Open-Source Code Released Today | praveen | Main CFD Forum | 1 | May 21, 2012 20:52 |
