Home > Forums > Visualization & Post-Processing Software > Tecplot
how to make tecplot to use only static temperature
Old   March 4, 2016, 19:08
Default how to make tecplot to use only static temperature
Hadi
Hadi Khabbaz is on a distinguished road
hi all
when i use cas and data file which they were created by flunet directly into tecplot and then plot my temp or velocity contours on a slice, tec plot would somehow make displacement in contours on different zones and because of that, contour lines at the interface of the zones are not gonna match properly and there gonna a jump or gap between contour line at the interface of the zones.
so i tried another way and i used export option in fluent and for example i export static temperature specifically for tecplot. and then i used that export in tecplot and all of the sudden everything is FINE !!!
but when i do this, i can not use slice option in tecplot since there's no case file imported in tecplot and also there is no option for making contour lines appear in "contour" detail in tecplot (there's an option for that in slice section in tecplot)
so now my question is how to use the normal cas and data file written by fluent and making tecplot only use the static temperature ?
thanx in advance
appreciated
Hadi Khabbaz is offline   Reply With Quote
How to make the axis value change with an animation when using tecplot? bhbuaa Tecplot 0 August 12, 2014 12:10
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 16:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 00:49
Static and Total Temperature Tomislav FLUENT 4 December 4, 2006 04:59
Static temperature David FLUENT 2 April 1, 2005 10:57
