March 20, 2014, 21:02 |
Surface Area
Rep Power: 12 |
I am trying to compute the chocked flow area of my results. On a program I interpolated for the coordinates for Mach one. Is there a way to get Tecplot to compute each individual cell area? Or maybe simpler, is there a way to get it to compute the entire surface area for Mach 1 from the entire solution? Thank you! Any help or suggestions would be appreciated. |
March 21, 2014, 09:29 |
Scott Rumage
Rep Power: 17 |
One suggestion is to extract an isosurface of Mach 1 to a new zone. Then via the Tecplot 360 menu go to Analyze>>Perform Integration then select “Length/Area/Volume” to find the surface area of the extracted isosurface zone.
Genias Graphics, the European distributor of Tecplot, has created a nice recording of their webinar on post-processing measured (wind tunnel and PIV) aero data in Tecplot. Here is a link to that recording: https://www1.gotomeeting.com/register/491891489 . The meat of the webinar starts at around 2:30 where he reviews loading test data and creating an I,J,K ordering so that Tecplot understands the connectivity between the data. At around the 19 minute mark, the presenter shifts to showing Tecplot Chorus which is designed to plot, manage, and understand groups of plots for a given project. You may find the plotting practices presented in the webinar of help to your work. Note that you do have to register (share your email address) to view the webinar. Scott |
March 21, 2014, 09:54 |
Rep Power: 12 |
Thank you! Your first suggestion works perfectly. I will still watch the seminar to learn some useful tricks.
February 16, 2016, 07:54 |
#4 | |
Qureshi M Z I
Rep Power: 12 |
thanks |
February 16, 2016, 12:15 |
Scott Rumage
Rep Power: 17 |
Tecplot does not track nor change the type of units of a variable. So if the data started in "m" (or meters), then the results will be in meters.
February 16, 2016, 13:18 |
thanks
Qureshi M Z I
Rep Power: 12 |
thanks Scott for the quick reply. i am working on this, if i feel any difficulty i will share with you. thanks again
choked area, choked flow, surface area |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[ICEM] How to build the mesh for 3 injection area within one surface? | Ryan_Yang | ANSYS Meshing & Geometry | 11 | April 8, 2012 14:20 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
B.E.T surface area??? | WASIM | FLUENT | 0 | September 1, 2008 00:33 |
Surface area of free surface | jaswi | OpenFOAM Post-Processing | 0 | July 25, 2007 14:34 |
