[ICEM] How to connect 2 cylinders that are perpendicular to eachother
Old   April 18, 2012, 09:23
Default How to connect 2 cylinders that are perpendicular to eachother
Sören
despaired student is on a distinguished road
my questions here are connected to a topic discussed earlier - http://www.cfd-online.com/Forums/ans...ks-defect.html
From the above discussion I received a good 2-D mesh of the top of the large cylinder which can be extruded by 70 (less (40, 35, 5, etc) didn't work satisfyingly, don't know why?). Now I need to mesh the in- and outletpipes and connect them to the existing mesh.
Meshing a pipe respectivly a cylinder isn't a problem any more... but what is a problem is the connection to the existing mesh.
How do I do this? Can I put an O-Grid through the pipes + the large cylinder when there are several smaller cylinders (solid) crossing the way of the O-Grid?
If this is the way how must it be done?
The pipes I need to connect are the parts: Inlet, Inlet_pipe plus Outlet, Outlet_pipe
When the mesh is finished I want to use OpenFoam for calculation.
Best regards
despaired student is offline   Reply With Quote
Old   April 18, 2012, 09:30
Default .blk-files
Sören
The .blk file is too big to attach it but you can use the .blk - file here attached. Use creat block>>2D to 3D>> Method: translate -> Z-direction: 70.
Before doing this I had to dissociate all edges and vertices. Then translate, activate the following parts: INNER_CYL, OUTER_CYL, all of the membrane circles (1-4), FLUID, TOP_SURFACE.
Then click Blocking>>Associate>>update association (enable: Edges, Vertices).
Can't connect volumes in Gambit villager ANSYS Meshing & Geometry 4 October 18, 2011 17:10
[ICEM] generating tetra mesh on various cylinders at the same time karananand ANSYS Meshing & Geometry 2 July 9, 2010 16:34
Meshing Volume between Cylinders Sidewinder ANSYS Meshing & Geometry 4 March 29, 2010 07:58
connect failed with errno%3d113 wedsall OpenFOAM Running, Solving & CFD 2 November 3, 2008 04:17
Heating Element w/ Perpendicular Fins Ryan FLUENT 1 August 27, 2004 12:01
