[ICEM] How to make Hexa mesh for this geometry
Like Tree1Likes
  • 1 Post By Far
Old   July 16, 2012, 07:32
Question How to make Hexa mesh for this geometry
lnk
lnk
lnk is on a distinguished road
Here is my problem. The Y-block doesn't work well. May I ask how to deal with this geometry?
Best regards and many thanks,
lnk
lnk is offline   Reply With Quote
Old   July 16, 2012, 08:53
Christoph
energy382 is on a distinguished road
you have to extend split or to modify your edge params like linked bunching
energy382 is offline   Reply With Quote
Old   July 16, 2012, 10:37
lnk
lnk
Thank you for your answer. I really don't understand which split should I extend, to which place, and how could it solve my problem?
Best regards,
lnk
Old   July 16, 2012, 12:07
Far
Sijal
why you need Y block?
Old   July 16, 2012, 12:10
lnk
lnk
Because there is a triangle over there. So I'm thinking about using Y-block to solve that problem. If there's any other way to solve this problem, I'd also like to know.
Best regards,
lnk
Old   July 16, 2012, 13:29
Far
Sijal
Here are two methods. First method uses files you just posted with extended split and then another blocking without y-block. See the difference.
PSYMN likes this.
Old   July 17, 2012, 16:28
PSYMN's Avatar
Simon Pereira
I had downloaded this earlier and just came to post my answer. I see that Far already beat me to it with the correct answer.
Actually your first blocking is fine. All I did was update the mesh sizes (Blocking (tab) => Pre-Mesh Params => Update Sizes => Update All) and recomputed the premesh to get this...
You could go with the simpler blocking as Far showed, but there are situations where that quarter Ogrid blocking would be better... For instance, if you had an inner baffle that went part way up the side (between the Ogrid and the side block) or if you had a lot of flow gradients in that region which needed increased resolution (independent of the rest of the model)...
It it is really one volume with no special mesh focus needed, then just stretching the Ogrid to fit the shape is probably easiest and best.
Hexa is very flexible, keep at it and you will do well. Just remember that the blocking topology doesn't need to match the surface topology.
CFD Online Users Survey
[ICEM] Creation of hexa dominant mesh and prism layer gnuboard ANSYS Meshing & Geometry 7 January 11, 2018 04:13
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
