October 23, 2012, 16:32 |
fixing of geometry
Ugly Kid Joe
Rep Power: 15 |
Hello all,
I would like to join the 2 surfaces that are denoted by a yellow border. I have attached the images with this post. http://imageshack.us/a/img33/8186/linesgp1.png http://imageshack.us/a/img24/404/linesgp2.png I have tried a couple of things but none seem to work. any help is kindly appreciate. The geometry it self was broken when I imported it to ICEM. Thank you very much. |
October 23, 2012, 20:24 |
Ghazlani M. Ali
Rep Power: 29 |
my be setting a higher tolerance in the build topology will work, if not, this will work:
Create one point in one of those curve. Create a second point in the other curve. (use project point on curve) so they can be aligned. next create an edge between these two points. After that create a surface using the driven curve. select circular curve as driven, then edge as driver (i dont remember the names first one is driven for sure don't remember the second) . I hope you got my point. If not share you geometry i can help you do that. |
October 23, 2012, 23:56 |
@ Ali
Ugly Kid Joe
Rep Power: 15 |
thanks Ali. i will try this tomorrow and let you know how it went.
October 24, 2012, 17:20 |
Ugly Kid Joe
Rep Power: 15 |
Thank you very much. It worked just fine.
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
STL Surface Geometry Fixing | EphemeralMemory | Main CFD Forum | 2 | October 31, 2010 13:35 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
Simulation of Flow through Complex 3D Geometry | EmersonKB | CFX | 5 | July 2, 2009 08:17 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
