[ICEM] Unable to split Blocks
Old   December 4, 2012, 11:33
Default Unable to split Blocks
Giuse
UDS_rambler is on a distinguished road
Hi everybody,
I'm new to ICEM and I'm facing my first issues trying to create a hexahedal mesh of a bifurcation (see attached figure).
I must say I was quite into Gambit's way of thinking and, maybe, it made me approach not in the ideal way.
I know it is possible to use the blocking approach to produce hexadral meshes and I made several tutorials to improve my skills in it.
I thought of creating a T shaped block to be associated to my real geometry. To do so I start from the box in the picture and then I try to split it in for parts. When I split the block (in the picture you can see just the horizontal splitting), I got the following message:
Split value: 0.609657
so I figured out splitting was done. Unfortunately, no new block edge is visible and if I turned on the blocks in the model tree, only one block (the original one) was still visible.
Playing with the visualization paramaters, I noticed that if I turn off Model>Blocking>Blocks>Whole Blocks I will see four blocks, but I still can't select or delete anyone of them.
Honeslty, I don't know what's the matter. Probably I'm mistaking something, but what?
Thanks so much for your attention
Yours sincerly
Giuseppe
UDS_rambler is offline   Reply With Quote
Old   December 5, 2012, 03:54
Giuse
SOLVED!!
I don't know what happened but now I can do it successfully!
Thanks a lot anyway!
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 09:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[ICEM] Deleting VORFN blocks in ICEM CFD Sai Swaroop ANSYS Meshing & Geometry 5 October 18, 2011 10:26
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
