[ICEM] Locked node numbers on edges are changed by ICEM
Old   March 5, 2013, 07:56
Default Locked node numbers on edges are changed by ICEM
bl!nk is on a distinguished road
Hello everyone, I am running into a bit of a problem and I wanted to ask, if someone here knows a solution.
I am trying to 3D hexa mesh the geometry of a furnace with a dummy load. I have got around 30 blocks or so and the edges don't all line up. E.g. I have 5 edges which have the same number of nodes combined as 1-3 other edges combined further down the x-axis. What I want to have is a symmetric mesh, so I enabled "Nodes/Parameters locked" on 4 of the 5 edges (the outer ones) in order to force ICEM to change the number of nodes on the edge that isn't locked (the one that is split by the symmetry axis) if I change something on the 3 edges. But even though the number of nodes is locked ICEM sometimes changes it instead of the number on the "free" edge. Is there maybe any special sequence I need to follow when I set the parameters on the edges, e.g. set the "free" edge last? Or is there any "real hard lock" feature where ICEM can't change the node number on its own anymore?
I hope the image below can help in understanding my problem.
bl!nk is offline   Reply With Quote
Old   January 30, 2018, 19:05
Michal
michal.s is on a distinguished road
Hello there,
Have you solved your problem with floating nodes number? I have the same issue.
Best regards
michal.s is offline   Reply With Quote
Old   January 31, 2018, 06:14
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Imagine this as having two edges in parallel. Edge One which is longer and the other one (edge2 ) which is same length but divided into 3 pieces in length ratio 0.1:0.9:0.1.
Let's say have 30 nodes on edge 1 (longer and splits).
And on edge 2 you have nodes in this ratio of 5:25:5. That's 5 nodes extra to the other parallel edge. (which is not permissible in ICEM or structured meshing).
So even if you lock parameters the program is going to have change one of the edges
shereez234 is offline   Reply With Quote
Old   February 3, 2018, 07:32
Far
Sijal
It is one to one correspondence, how you can lock nodes on one edge and change on other?
Edges association in ICEM Santiago Orrego. CFX 10 July 26, 2020 11:45
BEGINNER ICEM edges of splitted blocks guest7777 CFX 2 October 15, 2007 11:30
merging edges in ICEM Virag Mishra CFX 4 August 24, 2007 06:06
ICEM clustering of mesh points and multiple edges webhaw CFX 4 July 25, 2007 16:29
Icem CFD 10: Align vertices of splitted edges Michele CFX 2 March 11, 2006 10:07
