[ANSYS Meshing] ANSYS 14.0 Workbench ICEM CFD Interactive meshing
Old   May 27, 2013, 11:05
Default ANSYS 14.0 Workbench ICEM CFD Interactive meshing
Bill Tuer is on a distinguished road
I'm trying to do a similar meshing like in this tutorial video:
http://www.ansys-blog.com/2012/10/04...d-interactive/
At the beginning in ICEM CFD I want to replace the initial block by a new one - so I did it like in the tutorial and closed the blocking, generate a new initial block with the name of the deleted block and associate the edges.
If I generate the pre-mesh, convert it to unstructed mesh and go back to the workbench meshing I get two errors with a long unspecific text which meens in rough translation that some elements can't assigned to some objects...
Nevertheless the mesh is correctly shown but can't used.
In both cases I used the default values and changed nothing from one try to the other.
So I tried a lot of things and come to the following:
- if I use the automatic generated block everything is fine
- if I replace the initial block with a new one the errors occur
It seems that the automatic generated block is 2D because I only get a mesh on the surface of my geometry but I need a 3D mesh.
(I also tried to replace it by a new 2D block - I doesn't work, too)
So what can be the reason and how can I get it working?
I hope somebody can help me...
Update:
Okay the automatic generated block is 3D swept block. I tried to change it to mapped but it doesn't worked because the "corners are not clear".
Bill Tuer is offline   Reply With Quote
Old   May 29, 2013, 11:49
Matthias Voß
mvoss is on a distinguished road
did you associate ALL points and lines in your blocking?
mvoss is offline   Reply With Quote
Old   May 29, 2013, 13:17
Yes, but I think thats the point.
I tried several things, e.g. just to disassociate one vertice or one edge - and then the back transfer failed.
But I didn't get it with a new block working, either. I split the block several times and associate all vertices and all edges to points and curves.
The inital block is a single one (swept) and all vertices and edges of this one are associated to the geometry. But I want to have several splitted blocks to get a straight mesh.
Old   May 30, 2013, 03:51
Matthias Voß
i would guess it is because of the changed blocktype.
are u running 14.5? There is a new ICEM container which i am using all the time, and a tcl/tk script and everything works quite well (updating geometry, automatic hex meshing with different blocking, and mesh refinement e.g.)
Old   May 30, 2013, 10:51
No, as I mentioned in the title I am running 14.0 and I don't have the possibility to use 14.5.
My intention was to use the interacitve ICEM meshing inside a Workbench remeshing script. But in the meantime I have to notice that this doesn't work. If I start the meshing process the recording stops with the hint that a batch process is starting which can't recorded.
So it seem I have to find another way to realize my project...
Maybe I start a new thread on this topic - I want to remesh in ICEM with an updated geometry after a non uniform deformation on a boundary (CFX) - or has someone a tutorial or good source as a starting point for me?
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes rooftop ANSYS Meshing & Geometry 19 March 31, 2016 02:33
Scale meshing ANSYS ICEM CFD Giannis191919 ANSYS Meshing & Geometry 0 September 30, 2011 05:47
Tips of ICEM CFD meshing speed up CFD_D_BOY ANSYS Meshing & Geometry 1 September 7, 2011 02:53
Complex .stl data for volume meshing in ICEM CFD Nils_H ANSYS Meshing & Geometry 5 September 2, 2011 08:39
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 16:14
