July 2, 2015, 21:11 |
Generate Mesh on Internal walls
Vinícius da Costa Ávila
Rep Power: 10 |
Could anyone give me some advice here? I have introduced internal parts in my geometry and I have created new parts to name them. However, when I visualize the pre-mesh and even after I export the mesh, these internal parts just vanish. The external parts: walls, inlet and outlet are ok, but the internal ones (membrane, cilindres and baffle) weren't export with the mesh. I have attached 3 prints, screen1: my geometry (walls in green, inlet and outlet in red, baffle in pink and membrane and cilindres in blue) screen2: the pre-mesh, where we can see that the mesh were generated on the inlet and walls. screen3: unchecking the walls (with the pre-mesh checked) we can see no mesh on the internal parts, just on the inlet and outlet (in red). Anyone has any idea what I have missed that the exported mesh doesnt carry the internal parts? Thank you, Vinícius |
blocking, internal baffle, internal parts, internal wall, mesh |
[ICEM] Defining Interfaces and Splitting Internal Walls ICEM-FLUENT | pmtgt | ANSYS Meshing & Geometry | 8 | June 4, 2021 07:15 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 18:48 |
[ICEM] Generate multiply bodies and then mesh them one by one | hz283 | ANSYS Meshing & Geometry | 1 | March 3, 2013 15:27 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
