August 11, 2013, 10:08 |
mesh quality
Rep Power: 13 |
Dear all,
I am going to model two pipes as you can see.A block (pipe wall) is made as a part for making pipe wall. there is some bad meshes on pipe wall. How can I improve the mesh quality in this part.I have attached the Icem document too. Thanks icem file : https://hotfile.com/dl/239028725/c81cafd/mesh.rar.html |
August 11, 2013, 17:34 |
Rep Power: 13 |
Just have a look at the attaches if you like.
Block strategy I followed is: - initial block for external pipe - ogrid on its 2 faces for the outer skin of the inner pipe - ogrid on its 2 faces for the inner skin of the inner pipe - split on vertical and horizontal edges of the blocks - ogrid on each of the 4 faces of the inner block (on both sides) ..but why you use angle as criteria of the quality of the mesh? |
August 11, 2013, 23:50 |
Rep Power: 13 |
Dear Crostolo,
Thank you for your reply.There is an error for my mesh file that non-positive volumes exits.Sothat I used angle as criteria.Do you have any suggestion for improving mshes in inner pipe wall considering my blocking strategy ? |
August 12, 2013, 13:17 |
Simon Pereira
Rep Power: 47 |
You appear to have constrained the shape of the inner block to a circle...
If you do not need to constrain that inner block... Then change the edge projection to surface so that it will stay square... If you do need that circle, then put an OGrid inside that block so that there is a square further in...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
August 12, 2013, 14:30 |
#5 | |
Rep Power: 13 |
Thank you so much.I found a point.Bad quality of mesh will appear after creating a part of the marked block (the associated block to inner pipe skin).I tried it on your file too.Quality of mesh is good at first and will export correctly.But I need to define the skin pipe as wall boundary condition.Therefor I created a part from the associated block to pipe skin.After that fluent will show same error.(non-positive volumes exits).do you have any suggestion for this problem? |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Polyhedral Mesh Quality in Star-CCM+ | niazaliahmed | STAR-CCM+ | 3 | March 8, 2012 13:51 |
[ICEM] Tetra mesh quality before and after prism layer | Chander | ANSYS Meshing & Geometry | 0 | December 25, 2011 22:04 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
