[ANSYS Meshing] Problem with Named selections/stairstep mesh
Old   September 8, 2013, 17:26
Default Problem with Named selections/stairstep mesh
Prateek Anand
Thermal_engg is on a distinguished road
Hello everyone,
I have been working on a geometry which is completely closed loop and is somewhat rectangular and bifurcates in to two branches at a point and then rejoins the main line some distance later.
I need to be able to adequately capture the turbulent boundary layer,so I added some inflation layers in the Mesher.Initially the mesher was giving the message "Inflation caused stairstep mesh at some locations".
To avoid the above message,I reopened the design in ansys DM and sliced the geometry at the 4 junctions using "Plane slice" option.Then again opened the mesh in the Mesher and meshed using the same conditions as before,and this time it does NOT give any error.
So now I proceed to create named selections of various parts.As soon as I am finished with named selections,Mesher shows the "mesh update" icon.Very well, I update the mesh again and I start getting the errors like "Stairstep creation...." again alongwith a new error "Pre-inflation method stopped....".
Am I committing some silly mistake here?Any help is appreciated.
I am attaching picture of the geometry.
Thankyou.
Thermal_engg is offline   Reply With Quote
Old   September 13, 2013, 03:40
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Where is your stair stepping? If it occurs because the inflation layers of different walls are interfearing with each other, then you need to change the height of you total inflation or change to layer compression instead of stair stepping.
jrunsten is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Dynamic Mesh Problem. Tom Clark FLUENT 10 June 21, 2021 04:27
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
problem when I import mesh with cyclic graduated BC Cyp OpenFOAM 0 March 3, 2011 10:38
