[DesignModeler] Extra faces detected in geometry |
August 21, 2013, 03:08 |
Ajinkya Pandit
Rep Power: 14 |
Hey all,
I have been working on this issue for some time and I can't figure it out. The case is fairly simple. I wish to simulate a 2D stirred tank. To do this, I have a square which represents the fluid. Then there is a small rectangular zone inside it which will act as the impeller. Later I will specify fixed velocity in this zone. Now to the issue. I create named selections seperately for the outer fluid zone and the impeller zone. Also a named selection for the outer wall. The issue is in addressing the interface between the impeller zone and the outer zone. When importing in FLUENT, it treats it like a wall, and I can't change it to interior. It would be great if someone could help me out. Thanks in advance. Ajinkya |
August 21, 2013, 03:24 |
Paritosh Vasava
Rep Power: 22 |
Did you subtract the inner zone from the outer zone? I mean that are you sure that you have two different zone: one impeller and the other as fluid.
August 21, 2013, 04:42 |
Ajinkya Pandit
Rep Power: 14 |
Hey,
Yes, I am sure that there are two zones. I can name them seperately. I have created the geometry using Design Modeller and have kept the first surface as frozen while making the second surface. I have not subtracted the surfaces but rather created two surfaces from two sketches. I will check how subtraction can make a difference. Thanks, Ajinkya |
August 21, 2013, 04:59 |
Paritosh Vasava
Rep Power: 22 |
Subtraction is the only way to make an interface. Once you make the subtraction either Ansys meshing will automatically create an interface or you can create it from 'connections'.
August 21, 2013, 05:23 |
#5 | |
Alex
Rep Power: 46 |
Then in the Ansys mesher create two named selections from the two surfaces. This way, there wont be any walls between the domains and you wont even need interfaces. |
August 21, 2013, 05:43 |
Rep Power: 12 |
Hey,
Yup that did the trick. Just learned that this called a multi-body part. Thanks for your help vasava and flotus1. Ajinkya |
geometry, interface, shadow wall |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
decomposePar pointfield | flying | OpenFOAM Running, Solving & CFD | 28 | December 30, 2013 15:05 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
[GAMBIT] Problems in forming faces for a complex geometry | Lenovo | ANSYS Meshing & Geometry | 1 | June 15, 2009 00:52 |
