[GAMBIT] Gambit meshing
Old   August 23, 2013, 04:37
Default Gambit meshing
Manish
Manish31aero is on a distinguished road
Hello friends...
I am working on an annular diffuser geometry having two sections
1. 18 degree diffuser
2. 5 degree diffuser
The diffuser have shaft and 5 supporting struts extended from hub to casing .
At the joint of strut at hub and casing i have made fillet.
The problem is with fillet geometry i am not able to mesh it properly. I have to attach boundary layer at the casing as well as hub.
Both copper scheme and tet/hyb scheme is not working.
without fillet i have already meshed. but with fillet gambit is showing error.
Please help..
thank you so much.....
Manish31aero is offline   Reply With Quote
Old   August 26, 2013, 01:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
post pictures please
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 26, 2013, 10:11
Smile
Manish
Hello Sir
I have attached pic of my geometry
Thank you for your reply
Please have a look on this
Old   August 27, 2013, 00:32
-mAx-'s Avatar
Maxime Perelli
-If your physics enables it, you may work with symetries or peridoicity
-Reagarding your problem, if you display a little more, and specially in the area of your fillet, maybe we could see where the problem is. But I would say, you could handle this issue with a size function on the fillet (refinement on the fillet)
[ICEM] ICEM sizing function >>> Gambit and Ansys meshing Far ANSYS Meshing & Geometry 0 March 3, 2013 10:17
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
problem with gambit unsymmetrical meshing meenakshi FLUENT 1 March 28, 2008 12:46
meshing a fan using gambit tony FLUENT 1 February 15, 2008 00:28
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 19:06
