[ICEM] problem with blocks
Like Tree2Likes
  • 2 Post By cesarcg
Old   August 31, 2013, 07:31
Default problem with blocks
Pawel
pawel_sag is on a distinguished road
hi,
can someone little help me? how should i change block to get better quality of mesh? thx a lot for advice
pawel_sag is offline   Reply With Quote
Old   August 31, 2013, 15:16
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
why don't you give a try to the extrude blocking command?
cesarcg is offline   Reply With Quote
Old   August 31, 2013, 15:36
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
there is some gap between two surfaces in transition region. Also use exturde along curve command.
Far is offline   Reply With Quote
Old   September 1, 2013, 08:41
Pawel
ok i will try, but first i will have to learn how to use it. I start using icem few days ago. Thx for help,
it's again me. I can't find any tutorial or information how to use extrude. When i try to use it, i allways get some error..maybe someone know turial or video how to use it.
i try to mesh my profile in 2 diffrent way, but i still get bad element.
Old   September 2, 2013, 06:12
Javi
FJSJ is on a distinguished road
Hi Pawel,
If you want to create a surface between those two pipes you have to do:
1º - Create a representative curve of the surface to extrude.
Go to Geometry -> Create/Modify Curve -> Concatenate/Reapproximate Curves and choose the two curves (in Fluid_2 or Fluid_3) to form a circunference.
2º- Create a drive curve.
Go to Geometry -> Create/Modify Curve -> From Points and select one point in Fluid_1 and other point in Fluid_2.
3º- Create extrude surface
Go to Geometry -> Create/Modify Surface -> Curve Driven and select the curve created in third step and circunference created in second step.
aaextrude
FJSJ is offline   Reply With Quote
Old   September 2, 2013, 12:51
Pawel
i don't know how to create proper mesh for pipe with shutter.
Old   September 2, 2013, 12:57
Cesar
if you don't mind it'd be more helpful that you share the *.tin file.
regards.
Old   September 2, 2013, 13:05
Pawel
thanks you for all of your help and replies
Old   September 3, 2013, 15:29
Cesar
dear pawel,
first of all, i did a little modification of the geometry you provided in order to have a guide curve along the pipe of your model. i added also some points that may serve as reference to the blocking. i suggest you to start with a 3D blocking by selecting appropriate entities and also the desired options, for instance "project vertices and orient with geomtry". to initialize the first block you can select the entities (curves) shown in the picture below
to obtain a block aligned with the corresponding section of the geometry as depicted in the next figure.
after this procedure, you'll be able to use the command "extrude along curve" to generate the blocking for the rest of the geometry. please take care of the options "twist per layer" and "number of layers".
i came up with a topology (approach2) in which i obtained the premesh shown in the following picture,
however, using the approach2 the region of the shutter cannot be meshed due the position of this one. it'd be easier to do using the approach1. here are the geometry and blocking files.
regards.
César
energy382 and gk_uk like this.
Old   September 4, 2013, 05:51
Pawel
Thanks you helped me a a lot
Now I have a problem with Fluent, any advice for this simulation?
i try using model K-epsilon (Standraed, rng, realizable) and k-omega (sst).
Which algoritm is best ? Simple? or i have to try all of them and find the right one?
Old   September 4, 2013, 08:12
Cesar
you still have to deal with the meshing of the shutter.
Old   September 4, 2013, 10:00
Pawel
now i have something like this, there still bad elements but i will try to fix them
Old   September 4, 2013, 13:13
Cesar
i can't see very well the behavior of these bad cells. please show more closer views. are you using o-grid?
Old   September 4, 2013, 14:13
Pawel
yes i use it, maybe i did something wrong.
i add file with my actual version
Old   September 4, 2013, 15:43
Cesar
pawel,
you did the blocking in the wrong way. as i see from your actual version, you're sticked to the pattern of your first topology (i.e., trying to match the blocking with the geometry through horizontal and vertical splits). i also see that you didn't use the "extrude along curve" command since your actual version of the geometry lacks of a curve describing the path of the pipe.
check the blocking files that i provided you and compare them with yours, specially in the region of the twist of the pipe. you'll see the difference in the blocking and behavior of the mesh. also, revise again the above suggestions and pay attention in the part:
regards.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
