[ICEM] How to edit the existing mesh?
Old   February 24, 2014, 20:37
Default How to edit the existing mesh?
kaliramesh
kaliramesh is on a distinguished road
Hello Everyone,
I have generated a 3d mesh of rectangular block of 15*15*7.5 m3 in ICEM CFD. Now I would like to change the dimensions of it to 1.04*0.66*0.66 m3. For this do I need to redo my entire meshing or I can just change the dimensions and do it.
Thanks
SKR
kaliramesh is offline   Reply With Quote
Old   February 27, 2014, 16:14
Sebastian Engel
bluebase will become famous soon enough
You could use the scale features in icem. It's possible to scale geometry entities, the blocking and also elements itself. But this might not be very elegant.
Try recording a replay script. Then you could change the dimensions in this script and have the mesh the same way you created for different dimensions.
Well, for a simple rectangular block... if you only have to redo it once, restarting from scratch doesn't need much effort either.
bluebase is offline   Reply With Quote
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Creating new mesh from existing mesh az_f ANSYS Meshing & Geometry 5 January 18, 2010 23:12
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
