[DesignModeler] 2D multi-material model
Old   March 3, 2014, 14:34
Default 2D multi-material model
Unknown
darijus is on a distinguished road
Good evening,
I am doing university project where I need to model thermal processes in waste nuclear fuel cask (CASTOR type).
I never used ANSYS before so I have struggling with creating model. Main problem I have is how to design multi material object? This cast should be designed in 2D.
I tried to use: Surface from sketch (drawing every single part of cast as new sketch). When I finished one, I frozen it and draw second one. It looks good in designmodeler as I have 7 separate bodies generated but I have problems when trying to do calculations in FLUENT.
Is it correct way to draw multi-material model? I uploaded my design:
http://darijusgliding.com/personal_files/model.zip
It is created with ANSYS 14.0.
Can anybody suggest proper way of creating such model? Or even somebody can take a look to my model and comment what is wrong?
Thank you very much,
Regards,
Darijus
darijus is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Air-7 multi species model JAlbert SU2 Shape Design 3 January 14, 2017 09:46
using interface with Euler multi phase model karimi FLUENT 0 May 22, 2011 02:46
using interface with Euler multi phase model karimi Main CFD Forum 0 May 22, 2011 02:39
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
