[ICEM] ICEM Prism interaction with multiple edges
Old   August 7, 2014, 16:08
Default ICEM Prism interaction with multiple edges
Daniel Wilde
QCFD is on a distinguished road
I am generating a mesh which includes many internal 2-D Baffle surfaces. There are heat exchangers up against the baffles which need to be prismed.
I am having difficulty with ICEM terminating the prisms by stair stepping rather than terminating up against the baffle (resulting in quads). Is there a prism setting (or other setting, or surface orientation solution) which will allow the prism to terminate by colliding with the thin baffle?
The angles are all 90 degree so this should be fairly straightforward for ICEM to handle.
Regards
QCFD is offline   Reply With Quote
Old   December 25, 2014, 06:54
Eugeniya
Eugeniya is on a distinguished road
hello!
tell please, you solved this problem? If yes, that as?
thanks
Eugeniya is offline   Reply With Quote
icem, prism
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
ICEM 5.1 to CFX Prism Element ashish CFX 1 April 6, 2005 18:32
