[ICEM] Meshing Perforated plate
Old   October 5, 2014, 09:28
Default Meshing Perforated plate
Ebrahim
Ebrahim is on a distinguished road
I want to generate a structured grid for a perforated plate.
As you can see in the attached image, the holes of the plate have an organised pattern.
I'm looking for a fast method to build o-grid blocks for generating structured grid both inside and (if possible) outside the holes.
What is your opinion(s)?
I appreciate your helps,
Ebrahim
Ebrahim is offline   Reply With Quote
Old   October 7, 2014, 05:19
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hello Ebrahim,
Well I would create a blocking around a single hole of your plate (with 2 O-grids, one for the hole and one around for the BL), and then copy the blocking with the ICEM "transform block" tool.
Gweher is offline   Reply With Quote
Old   October 7, 2014, 14:10
Ebrahim
Originally Posted by Gweher View Post
Hello Ebrahim,
Hello Gweher,
Thank you for your reply.
This is a good suggestion, however, the problem with this method is that associating the edges of the copied blocks to their relevant curves is time consuming!
A practical solution to the new problem perhaps is to copy the hole which is inside the first block and remove the previous holes! However, It's better for my case to keep the original holes!
I appreciate your help.
Ebrahim
Old   October 8, 2014, 07:22
Dr. Flow Squad
Dr. Flow Squad is on a distinguished road
Maybe this can help:
https://www.youtube.com/watch?v=pehn_0RONb4
Dr. Flow Squad is offline   Reply With Quote
Old   October 8, 2014, 17:23
Ebrahim
Originally Posted by Dr. Flow Squad View Post
Dr. Flow Squad,
Thank you for the interesting video. It is very useful.
I'm wondering if I need to copy the geometry while I copy the mesh or...?
Perforated plate franzdrs Main CFD Forum 16 November 12, 2017 05:48
[ICEM] Meshing of a Flat perforated plate (Zero thickness) hammer ANSYS Meshing & Geometry 6 December 23, 2015 09:54
Modeling of perforated plate for 3 phase fluidized Sanyo FLUENT 5 March 27, 2015 11:01
Need help on perforated plate with less than 2% open area sosososo1114 FLUENT 9 August 31, 2011 01:33
turbulence at a porous jump (perforated plate) andrew FLUENT 1 May 8, 2004 09:51
