[ANSYS Meshing] tutorials and density increase |
December 15, 2014, 15:14 |
zduno
Rep Power: 12 |
Hello guys, I am a newbie and I have some newbie questions for you:
1. Can you recommend me some ansys mesher tutorials that you find "good" ? 2. How do I increase mesh density in the part inside a circle (see pic)? |
zduno
Rep Power: 12 |
ok, it's not a circle but an elipse, sorry
December 15, 2014, 17:32 |
#3 | ||
Rep Power: 14 |
Hi Zdunol,
Welcome to CFD Online. You can visit Ansys website>Customer Portal, its is packed with many tutorials for each workbench application.The tutorials come as .pdf files or flash videos, along with relevant models/meshes. Quote:
or you can use drop down menu from Mesh>Sizing>Type and give sphere of influence, it creates a sphere and gives element sizing only in that sphere region. Hope it helps, Cheers KAPI |
December 16, 2014, 09:56 |
zduno
Rep Power: 12 |
thanks man, i couldn't do it with sizing and i suspected that sphere of influence may be the right tool, but i don't know how to use it yet ;d Once again - thanks a lot!
December 16, 2014, 18:33 |
#5 | |
Rep Power: 14 |
Hi zdunol,
1. Create a Coordinate system where you want Sphere of Influence 2. To create new coordinate system, right click on "Coordinate Systems" in the tree on left side of meshing and select "Insert>Coordinate system" 3. Select geometry (point/edge/face/body) where you want Sphere of Influence 4. Then for mesh right click on "Mesh" in the tree on left hand side and select "Insert>Sizing" 5. Select related geometry where you want sizing 6. Select Sizing>Type>Sphere of Influence from drop down menu 7. Select new coordinate system you have just created form drop down menu 8. Input Sphere radius and Element size you want in mesh. 9. Make sure your sphere covers all the area where you want finer mesh, if not change Sphere radius to accommodate it. Hope it helps you understands more. Cheers KAPI |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] (ICEM CFD) meshing over a cylinder | vmlxb6 | ANSYS Meshing & Geometry | 6 | August 11, 2010 14:37 |
Density values in ICEM | Wooster | CFX | 1 | October 25, 2007 18:27 |
Number Density Simulations | CFDtoy | FLUENT | 0 | April 18, 2005 18:27 |
