[ANSYS Meshing] Solar Chimney Power Plant mesh |
November 16, 2015, 13:20 |
Benjamin Harris
Dear all,
Thank you in advance for your time reading this. I am creating a CFD model of a Solar Chimney Power Plant where incident solar energy will heat the air within the geometry however unfortunately I am unable to create a mesh appropriate. My skewness value is far too large and despite my best efforts of altering sizes and inserting inflation I cannot lower my skewness value at all. So much so that when a calculation is run I get a suggestion to better my mesh and doing nothing results in a floating point error when calculations are run; I presume due to the poor quality of my mesh? Please see attached my standard generation mesh with associated skewness graph. While changing to smaller cell sizes improves its rating a little it is still not of satisfactory levels. Any help would be very very much appreciated as I am finding it quite difficult. Ben |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
To Study the flow of solar chimney/thermal chimney | ysh_kobe | FLUENT | 1 | September 21, 2013 02:17 |
bUOYANCY DRIVEN NATURAL CONVECTION FLOW IN SOLAR CHIMNEY | Surajtalele | FLUENT | 3 | April 26, 2013 10:09 |
