[ICEM] Looking for quick tutorial on creating unstructured mesh
Old   March 2, 2016, 06:25
Default Looking for quick tutorial on creating unstructured mesh
Phanikumar
phanikumar is on a distinguished road
Hi
Could any please tell me what are the steps involved for doing an unstructured mesh.As i am very new to Ansys Icem, i don't know completely about the unstructured mesh. I have read some tutorials , which i feel that they are not enough for me to do.
I am currently learning to mesh(unstructured) an Airfoil.Could anyone please tell me how to do it.
Thankyou
phanikumar is offline   Reply With Quote
Old   March 2, 2016, 09:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by phanikumar View Post
Hi
Thankyou
I will give you steps :
1. Import geometry and check quality of it. Set tolerance, units etc.
2. set global parameters and shell meshing parameters
3. set curve parameters if you want to use patch dependent
4. Set surface parameters (curve parameters if you want more control). Change method to patch independent in shell meshing.
5. Set inflation parameters for curves in part mesh setup and put no of layer, first layer height and expansion ratio.
6. Compute mesh and check quality.
7. If every thing is ok, then set boundary conditions, solver and output the mesh.
Far is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
