Fluent meshing problem
Old   April 14, 2016, 14:09
Arrow Fluent meshing problem
Kenneth
Kenty is on a distinguished road
Help needed to with meshing of a CFD simulation of combustion exhaust gas mixed with radial jet air stream down of a quenching region that essentially modeled with reference to the paper "CFD Analysis of Jet Mixing in Low NOx Flametube Combustors." by Talpallikar M.V., Smith C.E., Lai M.C. and Holdeman J.D. (http://gasturbinespower.asmedigitalc...icleid=1418419) My problem requires the jet air to be injected at a slanted angle of 3 degree and evaluate the effect on gases mixing and NOx emission.
I have tried to slice by surface to create a cylinder shape and 12 slanted injection slots. however, fluent doesn't recognise the cylinder as sweepable. Furthermore, when I attempt to use the multizone method with ICEM the hexagonal function expands beyond the boundary of the cylinder which happens similarly with the ogrid when I chose absolute with an offset of 1mm.
For further infomation, you can contact me through tyshuen@gmail.com.
Many thanks,
Kenneth
Kenty is offline   Reply With Quote
MPI problem with fluent aryanet FLUENT 17 October 30, 2017 21:04
facing problem in dynamic meshing motion preview in fluent hitesh0401 Fluent UDF and Scheme Programming 6 May 8, 2014 15:59
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 16:16
