[DesignModeler] Not ready? can't draw anything, can't import geometry
Like Tree2Likes
Old   June 11, 2016, 07:12
Default Not ready? can't draw anything, can't import geometry
Garab Ádám
GARAB is on a distinguished road
Hello all!
I'm new to the complete software family, I want to use it for masonry modelling. I wanted to do some tutorials, like creating a solid and put some force on, etc. , just to see how it work.
I'm using Ansys Workbench 17, student version, on Win 8.1 64 bit. I can change and set up the engineering data, but the design modeller don't let me draw anything, I can start drawing a line, but can put "down" the end of it. And I can't import geometry from other programs (Autocad 2016), because : "The selected file is of an unsupported or unconfigurated geometry type".
I have a little sign in the lower left corner. It's a check in workbench, but when I open up design modeller to make the geometry modell, I see a little red sign, like the "no entry", I attached a picture of it.
Thank you in advance,
Garab
aamerfny likes this.
GARAB is offline   Reply With Quote
Old   June 23, 2016, 23:01
karthikeyan
WOLVERINE77 is on a distinguished road
i am also having same problem, pls share me if u got any ideas on tat.
Are you fixed that problem
WOLVERINE77 is offline   Reply With Quote
Old   June 24, 2016, 00:47
Garab Ádám
No, not yet and I can't reach neither my professor or Ansys. I still have no idea how to fix this.
Old   June 27, 2016, 07:28
leasken is on a distinguished road
Do you have a DesignModeler license available? Usually that "No entry"-sign indicates that there is no license at the moment.
leasken is offline   Reply With Quote
Old   June 27, 2016, 10:31
Garab Ádám
Well, I downloaded the student version, and the student license, and installed as it was written.
You are right, that as I see, I don't have the license for DM. I simply have to link it, or there is something else?
It was written, that nearly everything is usable, only limitation is that there is a limit of usable elements, or I'm wrong?
Old   June 27, 2016, 18:49
Kapi is on a distinguished road
you can use most of the things including making geometry and importing geom.
Try to re-install license manager and link the license.
Kapi is offline   Reply With Quote
Old   June 28, 2016, 09:45
_G15_ is on a distinguished road
I have the same problem.
Installed Ansys on three different PCs, still not working.
For the student license you don't use the license manager, at least this is how I understood the instructions - you just set a variable for a license file.
http://www.ansys.com/Products/Academic/ANSYS-Student
_G15_ is offline   Reply With Quote
Old   June 28, 2016, 18:46
then check the if you have used the right location of license
Old   June 29, 2016, 03:09
I have downloaded the license file again and set a new direction.
Without the file Ansys does not start in the first place, so the location and the variabel seems correct to me.
Maybe a bad license file provided by the Ansys servers?
Old   July 3, 2016, 02:59
aamer
aamerfny is on a distinguished road
I have same problem , so please if you get any solution , post it here..
thanks
aamerfny is offline   Reply With Quote
Old   July 5, 2016, 12:32
Garab Ádám
As I see, the license file is not seen in the design modeler. It's not shareable as far as I see, but I don't understand why
I tried to contact Ansys, but after the automated email answer, that they will contact me soon nothing happens :/
Old   July 19, 2016, 12:55
Has anybody some new information?
I downloaded the new license file (11.July.2016), but still it does not work.
I although asked some people at the IT department of our university, but they didn't now what to do either.
Old   July 19, 2016, 18:39
on you computer there will be a utility under programs<ansys
"Server ANSLIC_ADMIN Utility" click that and see what it is telling you.
You can also see how many licenses you have and if its working.
Old   July 20, 2016, 01:26
As it seems there are licenses available, but nur server licenses?
File Type: png Bildschirmfoto 2016-07-20 um 07.09.23.png (57.2 KB, 52 views)
File Type: png Bildschirmfoto 2016-07-20 um 07.10.01.png (20.4 KB, 25 views)
Old   July 20, 2016, 01:30
You must have license at server location.
When loading your Ansys you have to give that server location for license.
I think thats what is missing
Old   July 20, 2016, 01:49
Can I do this now the program is installed or must it be deleted and re-installed?
I thought I did everything exactly as described in the instructions for Ansys Student (I did it 5 times )
File Type: jpg Bildschirmfoto 2016-07-20 um 07.47.00.jpg (122.5 KB, 40 views)
Old   July 20, 2016, 02:00
umm not sure about student license.
But if you installing on your system then server will be your system only
re-do the license installment thingy! license manager
Old   July 20, 2016, 03:54
Thank you very much. I have found a solution.
I downloaded the file again from the Ansys website, unpacked the zip at the desktop and copied to c:\program files\ansys inc\ but this time I was asked if I would like to copy the file as admin, which I did.
Not it works just fine.
You actually saved my master thesis.
Old   July 20, 2016, 20:12
Glad I could help, Good luck with thesis
Old   February 7, 2017, 01:12
David Angeles
eagesg is on a distinguished road
Could you please explain better what did you do? I am having the same problem and it is driving me insane
eagesg is offline   Reply With Quote
[DesignModeler] Unable to Import Geometry Alan212 ANSYS Meshing & Geometry 3 March 17, 2015 11:26
[Other] Import CSV File to CFX Geometry or ICEM emily.imdieke ANSYS Meshing & Geometry 0 September 9, 2014 10:49
[DesignModeler] problem with import geometry from catia pavilion ANSYS Meshing & Geometry 1 November 23, 2012 10:45
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 16:50
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
