[ANSYS Meshing] FSI Solid mesh only one element thick?
Old   September 22, 2016, 14:45
Default FSI Solid mesh only one element thick?
Mike Tree
treem22 is on a distinguished road
Here's the situation:
I am simulating an internal flow. I have a volume mesh for my fluid domain, but only have a surface defining the interface between my fluid and solid domain. Luckily, my solid domain is the same thickness everywhere. So, I pulled the interface surface into an ANSYS transient mechanical module in workbench and applied a thickness in the details menu of the Geometry branch of the tree (within Mechanical). Then, I created the mesh.
As you can see, the mesh only has one element in the direction normal to the surface? Is this because mechanical is assuming I'm using a shell type element here and those, by definition, are only one element thick?
I also tried to open the DesignModeler and apply a thickness to the surface here. I used the Thin/Surface tool to apply the thickness here, but there was no change to my mesh results.
Is my only option to go all the way back to a CAD program and create a solid from this surface by offsetting?
Any help will be appreciated!
treem22 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
CFX FSI Fatal Error unbanana CFX 0 October 3, 2015 05:57
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
