November 4, 2009, 21:33 |
confused on CFX error message
Rep Power: 16 |
Hi all,
I defined a region in CFX-mesh called 'wall', and these areas defining the region 'wall' will have inflation applied. an error from CFX-mesh is below: The location wall refers to 12 primitive regions that do not appear in the geometry. These regions are F4439.4437 ........ In the end, volume mesh is generated BUT with the inflation ignored or not produced. Why does this error occurs please? Has it something to do with my imported CAD please? I can select the areas which defines the location 'wall' in CFX-mesh. I can still import this mesh into CFX-pre but the named 'wall' doesn't exists, and other region names don't appear for selection either. i'm using ANSYS WB v11, CFX-Mesh v11.0, on a Win Vista 64-bit machine. Thank you for your kind attention and i look forward to hear of any suggestions/comments. Regards, mactech001 |
November 5, 2009, 05:45 |
Rep Power: 143 |
You have to reselect the wall regions for the inflation to apply to.
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
