Dynamic mesh element types
Old   February 27, 2010, 11:00
Default Dynamic mesh element types
Jonny
Jonny6001 is on a distinguished road
Hi, is there any guide or the like which recommends the type of mesh elements zones should have in a dynamic mesh simulation?
I am going to do a 3d dynamic mesh of engine in-cylinder, I have the 2d tutorial and have looked at the mesh construction.
I take it any actual moving grid zones have to be quad elements.
Any help would be greatly appreciated.
Thanks
Jonny6001 is offline   Reply With Quote
Old   March 1, 2010, 01:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
There is no recommendations, but I would use layering technic, so you can work with hexas or wedges where extrusion's direction is the same as your cylinder's axis. (you mentionned 3d-mesh, and quad are 2d-elements)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 1, 2010, 16:35
Jonny
Hello, thanks for your reply.
Sorry I means hex for 3d and quad for 2d, I am not sure whether to go for a 3d simulation now or try and get combustion working nicely on a 2d simulation.
Do you have any expericence with combustion within CFD?
Thanks a lot.
Old   March 2, 2010, 01:05
-mAx-'s Avatar
Maxime Perelli
If your model enables it, start with 2d calculation.
No experience with combustion
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
How to Us Dynamic Mesh in OpenFOAM lzgwhy OpenFOAM Programming & Development 4 November 6, 2009 05:18
Dynamic Mesh Pj FLUENT 1 March 12, 2007 15:16
