August 26, 2010, 10:13 |
[ICEM] Trying out with Hexa for a wing
Stuart
Rep Power: 25 |
Today I was given access to ICEM CFD v12.1 Hexa for a single CFD study. This is new to me as for the past few years I've only had Tetra/Prism. Having read many ICEM topics it seems that Hexa is the preferred method (especially from reading PSYMN's posts). Since I don't have long to spend using Hexa and I only need it to create some meshes of a single 3-D wing with the NACA 0012 aerofoil section could someone let me know how to get high quality meshes for a range of different angles of attack and wing quarter-chord sweep angles? The wing has: root chord = 0.5m tip chord = 0.2m semi-span = 0.7m taper ratio = 0.4 aspect ratio = 5.7 (from full span) quarter-chord sweep angle = 25deg twist angle = dihedral angle = 0deg I downloaded the ICEM tutorials from the ANSYS Customer Portal but the only Hexa ones I could find were for internal pipes flows. One thing that the tutorial slides didn't say was how to deal with an inflation layer. Is a dedicated thin block made at a surface from the required y+, growth rate and layer quantity or is this combined in a regular block? I'm sure people will say this is all very easy but I don't have long to get proficient with it as after the task I'll be back to Tetra/Prism only. Thanks. |
[ICEM] 3D wing tip | realanony87 | ANSYS Meshing & Geometry | 3 | November 6, 2019 13:34 |
3D Wing Analysis | Ed | FLUENT | 5 | April 13, 2019 13:07 |
Forward swept wing simulation | abid | Siemens | 1 | June 16, 2012 13:26 |
[Gridgen] Blocking topology for blunt wing | siw | Main CFD Forum | 3 | July 21, 2010 13:55 |
Tetra vs Hexa meshing for a wing | Gilles | Main CFD Forum | 1 | May 22, 2008 04:55 |
