[ICEM] Trying out with Hexa for a wing
Old   August 26, 2010, 10:13
Default [ICEM] Trying out with Hexa for a wing
siw
Stuart
siw will become famous soon enough
Today I was given access to ICEM CFD v12.1 Hexa for a single CFD study. This is new to me as for the past few years I've only had Tetra/Prism. Having read many ICEM topics it seems that Hexa is the preferred method (especially from reading PSYMN's posts).
Since I don't have long to spend using Hexa and I only need it to create some meshes of a single 3-D wing with the NACA 0012 aerofoil section could someone let me know how to get high quality meshes for a range of different angles of attack and wing quarter-chord sweep angles? The wing has:
root chord = 0.5m
tip chord = 0.2m
semi-span = 0.7m
taper ratio = 0.4
aspect ratio = 5.7 (from full span)
quarter-chord sweep angle = 25deg
twist angle = dihedral angle = 0deg
I downloaded the ICEM tutorials from the ANSYS Customer Portal but the only Hexa ones I could find were for internal pipes flows.
One thing that the tutorial slides didn't say was how to deal with an inflation layer. Is a dedicated thin block made at a surface from the required y+, growth rate and layer quantity or is this combined in a regular block?
I'm sure people will say this is all very easy but I don't have long to get proficient with it as after the task I'll be back to Tetra/Prism only.
Thanks.
siw is offline   Reply With Quote
[ICEM] 3D wing tip realanony87 ANSYS Meshing & Geometry 3 November 6, 2019 13:34
3D Wing Analysis Ed FLUENT 5 April 13, 2019 13:07
Forward swept wing simulation abid Siemens 1 June 16, 2012 13:26
[Gridgen] Blocking topology for blunt wing siw Main CFD Forum 3 July 21, 2010 13:55
Tetra vs Hexa meshing for a wing Gilles Main CFD Forum 1 May 22, 2008 04:55
