Scripting API Design Modeler - Spline
Old   November 16, 2010, 15:57
Question Scripting API Design Modeler - Spline
MM
mieszko1st is on a distinguished road
Hi
Need some help in Ansys Design Modeler scripting API. The goal is to write a script, which draws a spline using control points. According to DM API manual following functions are available : SplineXYW(x,y,weight), SplineKnot(knot), SplineCtrlPtEnd(beginParam, endParam, order, closed, rational, periodic)
I wrote some simple script,
  p.Sp7 = SplineBegin();
    with(p.Sp7)
      SplineFlexibility = agc.Yes
    SplineXYW(0.0,0.0,1);
    SplineKnot(0.33);
     SplineXYW(0.5,0.7,1);
     SplineKnot(0.55);
  SplineXYW(0.9,0.4,1);
     SplineCtrlPtEnd(0.0,1.0,4,0,0,0);
but the design modeler crashes after running the script. I guess that the functions or parameters in the script are wrong or not sufficient, causing the program to crash.
Do you have any experience in writing such scripts ? Any idea of correct syntax to draw a spline based on control points successfully ?
Thanks for any help
MM
mieszko1st is offline   Reply With Quote
Old   February 27, 2014, 11:13
federico
fedefrance is on a distinguished road
I have the same problem, did you find a work around?
fedefrance is offline   Reply With Quote
Old   March 1, 2014, 07:30
MM
I gave up modelling the geometry in Ansys Design Modeller and eventually imported geometry from external 3D modelling software (Pro/Engineer).
Old   March 3, 2014, 05:09
federico
Ok, thanks
I wil try to give the geometry by points and then let the design modeler interpolate. Something like what is explained here http://www.youtube.com/watch?v=6wQPeBpvwCk
design modeler, geometry, script, spline
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
Importing Points in Design Modeler danh ANSYS Meshing & Geometry 5 March 30, 2015 10:45
Modeling Terrain in Design Modeler Will C ANSYS 0 February 26, 2010 18:13
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
