February 3, 2011, 09:12 |
split
fatma
Rep Power: 15 |
Hello
I work with DesignModeler for a short time and a look for "split" feature. Where can i find it? Thank you in advance (i want to split a face by another face) |
April 29, 2011, 16:26 |
Rep Power: 17 |
excellent question, I am trying to do the same
May 12, 2011, 08:05 |
zhao xin
Rep Power: 16 |
You can try a command 'slice' .
May 12, 2011, 09:31 |
Rep Power: 17 |
slice how?
May 13, 2011, 04:26 |
Rep Power: 16 |
This is all in the documentation - which should be the first place you look for an answer. First go tools -> Freeze to freeze your bodies Then go to the create -> Slice menu. Try using slice by surface. |
May 13, 2011, 07:33 |
Rep Power: 17 |
Thank you for your reply
I looked in the help many times, don't understand anything How does one create a standalone face? I need it as a slicing tool |
August 4, 2016, 07:47 |
Split Volume
Rep Power: 10 |
Hello.
I want to model PCM by fluent so i need to create multi zones. i want to model my project by Ansys workbench not by Gambit.my question is how workbench can split volumes as like as Gambit,(i mean Design modeler)? as you know Gambit have split volume but i cant find it in Ansys workbench. Thank you. |
August 10, 2016, 02:31 |
Rep Power: 14 |
slice your volume,
go to help section look it up and do some tutorials |
August 15, 2016, 03:03 |
#9 |
Rep Power: 10 |
Hi.thanks for your answer..shall i ask you to explain more?
it is about two weeks i work on it and i cant find any solution. |
August 15, 2016, 19:00 |
split surface and slice body
#10 |
Omar jumaah
Rep Power: 10 |
to split the surface of geometry
1- select the surface then create a new plane 2- create a line that demarcate your division, on generated plane 3- tools / face split target face : select the required face tool geometry : points on the line 4 - generate to slice body into parts by sketch 1- create sketch in a new plane 2- extrude that sketch by choosing : slice material or you can slice the body into parts using planes I hope this will help jumaah |
August 17, 2016, 02:24 |
#11 |
Rep Power: 10 |
Hello.
thanks for your answer. |
[GAMBIT] Split volume - when reflecting volume, the copy blows up | enfinity | ANSYS Meshing & Geometry | 7 | May 3, 2011 02:13 |
[ICEM] Split O grid | BrolY | ANSYS Meshing & Geometry | 1 | July 2, 2010 09:23 |
how to split hex mesh in icem with desired height? | adam2008 | ANSYS Meshing & Geometry | 3 | August 27, 2009 14:59 |
split functioin in CCM+ | Peter Specht | Siemens | 1 | March 5, 2008 08:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
