April 17, 2019, 09:17 |
Help in Spaceclaim
Overijssel
Rep Power: 7 |
I am trying to design and do a CFD test of pump. This is where I have come so far. (Picture 1) The problem is that I cannot get the geometry of a single channel with an impeller. The single channel should look like the picture 2. I thought of creating a surface and splitting the fluid volume with the surface. The problem is How do I create the surface that is used for splitting the Impeller volume? I only need to get ONE FLUID CHANNEL WITH BLADE (Look in the picture 2). Any ideas? Please help |
[Other] Import airfoil SpaceClaim | myaero | ANSYS Meshing & Geometry | 4 | May 16, 2020 08:52 |
[Workbench] SpaceClaim Script Integration into WB Journal | mertal1905 | ANSYS Meshing & Geometry | 4 | May 11, 2020 17:18 |
[ANSYS Meshing] spaceclaim CFD meshing zone interface setting | yzhyan | ANSYS Meshing & Geometry | 1 | October 12, 2018 06:00 |
Importing geometry from spaceclaim to icem cfd | Sumanth Bhat | Mesh Generation & Pre-Processing | 1 | April 12, 2018 10:55 |
How well does Spaceclaim integrate with ANSA | laminarflow027 | Main CFD Forum | 0 | August 18, 2014 10:09 |
