January 28, 2012, 19:55 |
How to generate this kind of mesh?
Ming Cai
Rep Power: 15 |
Hi, everyone.
I saw some mesh posted by Simon and I think I need this kind of mesh right now. Can anyone tell me the steps to generate this kind of mesh? Thanks in advance It seems that he built prism layer on hexa elements. I had tried 2d surface blocking and generated hexa surface mesh, but when I tried to generate prism layer, some of hexa mesh turned in to triangles. I tried use Octree to fill the volume first and then generate prism layer, all the hexa elements became tris. I don't know how Simon build this mesh, it looks pretty good |
January 30, 2012, 03:43 |
Rep Power: 18 |
1. Create 2D blocking for all geometry.
2. 2D to 3D, with options > "Multizone Fill" and O-grid around a fuselage and wing, "Fill type" Advanced. |
January 30, 2012, 13:30 |
Ming Cai
Rep Power: 15 |
January 30, 2012, 17:35 |
Simon Pereira
Rep Power: 47 |
I will put together a tutorial for this as soon as I can (yes, I know I have been promising it for a while), hopefully this quarter. It can actually be done in about 5 minutes, but it takes longer if I need to explain it all. ;^) And for some reason, putting together a 15 minute demo seems to take all day.
Simon
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
January 31, 2012, 02:45 |
#7 | |
Ming Cai
Rep Power: 15 |
February 2, 2012, 07:07 |
MultiZone meshing
chor construcsao
Rep Power: 14 |
If it serves for stressing further more, I have been looking for this MultiZone solution for ages (more than 3 years). I am dying to see the solution! Why MultiZone approach (and maybe other bottom-Up features) is not so well documented?, appears a superb feature. Best regards |
February 2, 2012, 10:46 |
#9 |
Simon Pereira
Rep Power: 47 |
The general guideline would be to tell you how it works...
The first step is to Create a "2D surface Blocking" Multizone starts by looking at your geometry. You need to have topology built because it uses that to understand what surfaces are attached to what. If it finds a surface patch with 4 corners, it can map it. If it finds a patch with more or less corners, it can pave it. The topology info is used to connect all these blocks together correctly. If you set a tolerance or have dormant curves, it can merge patches together. After auto blocking all those patches (just a few seconds), it takes the mesh parameters from the curves (so you should set sizes to take advantage of this). You can then adjust this surface blocking in preparation for the second step. In addition to adjusting the topology to what ever you want, you should make sure that your perimeter is closed (no single edges). The second step is a 2D to 3D "Fill". If you set this to sweep, it looks for rings of mapped blocks which could indicate the sweep direction. It can imprint, etc. to automatically handle multi source and target as well as multi direction sweep. If the model just needs a regular fill... it uses code similar to the hexa dominant fill... But instead of filling a quad dominant mesh with hexas, it it fills the surface blocking with volume blocks. You can run Ogrid to insert a boundary layer and it works just like with regular blocking. If you are doing external aero, then the sweep or Hexa block fill are not likely to give you a good mesh. You should use the unstructured fill. This basically fills the volume with one of the unstructured fill options (like tetra), but then you can insert an OGrid to give a nice hexa boundary layer around the aircraft... All of this is done on the ICEM CFD hexa framework, so you can adjust verticies or edge distributions, etc. You can also change block types, etc.
February 2, 2012, 14:42 |
#10 | |
Ming Cai
Rep Power: 15 |
February 2, 2012, 14:59 |
#11 |
Ming Cai
Rep Power: 15 |
I got stucked in periodic conditions
February 3, 2012, 01:51 |
#13 |
Ming Cai
Rep Power: 15 |
February 3, 2012, 02:03 |
#14 |
Ming Cai
Rep Power: 15 |
I found this have problem on the tip of the airfoil with sharp trailing edge or similar shapes. When I tried to do 2d to 3d fill, it automatically deletes some surfaces...
Also there's some periodic issue... I set periodic in mesh tab, then 2d surface initialization, Edit block=>periodic vertices, I made all the vertices on the periodic surface periodic. the surface is tri-paved surface. It seems that all the nodes are matched, but the elements on the surface are not, the block faces are not periodic. I think it's because type of block face is "free". How to make free surface periodic? I had similar problem before when I tried to generate surface mesh then use Delaunay under mesh tab. Only octree give respect to periodic set up. The surface mesh generation seem ignored the periodic set up. Last edited by mingersai; February 3, 2012 at 16:45. |
February 3, 2012, 05:01 |
#15 |
AB
Rep Power: 21 |
February 8, 2012, 04:36 |
WOW this works!
#16 |
chor construcsao
Rep Power: 14 |
PSYMN, Thank you so much!
February 8, 2012, 04:42 |
#17 |
chor construcsao
Rep Power: 14 |
Mingersai,
Did you check the periodic faces by ploting them on the faces options?, sometimes the collapsed node have to be marked as "periodic" to make the face periodic (I remember they were marked in red color) cheers! |
February 8, 2012, 12:13 |
#18 | |
Ming Cai
Rep Power: 15 |
I had contacted customer support and got negative answer the periodic is designed for Octree method and mapped type face blocks They suggested me some tricky ways to deal with free type face, I'm still trying to make it work. My application is to fluent and it seems that fluent could define non-conformal periodic faces. I'll try either way.. cheers~~ |
February 11, 2012, 00:38 |
#19 |
chor construcsao
Rep Power: 14 |
mingersay,
yep in Fluent there is no problem defining periodic faces that are not conformal. I have use it many times. cheers |
February 27, 2012, 21:57 |
#20 |
Rep Power: 20 |
Simon when you will going to post the tutorial for generating this kind of mesh because the beginners like me are still waiting for it. I now it will take your time to prepare tutorial but it will help a lot people. Thanks
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
[snappyHexMesh] SnappyHexMesh not generate mesh first time | mavimo | OpenFOAM Meshing & Mesh Conversion | 4 | August 26, 2008 07:08 |
generate different mesh in CFX_MESH | Eric | CFX | 0 | June 23, 2006 09:09 |
