[DesignModeler] Problems uploading Solidworks model
Old   February 28, 2012, 11:44
Default Problems uploading Solidworks model
Duncan Weatherhead
duncan21187 is on a distinguished road
Hi All
I have just drawn a model car using Solidworks and am currently trying to import the geometry into Ansys using the usual plugin, but the attach keeps failing. I have also tried to import it separately as an STL file with the same result.
The car has been modeled mostly using the surface functions in Solidworks, with all faces knitted together and merged to form the final part.
Has anyone had experiences of this before, or found ways to stop Ansys continually rejecting Solidworks' geometry?
duncan21187 is offline   Reply With Quote
Old   February 28, 2012, 12:07
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
http://www.youtube.com/watch?v=6yyPC9gXZZ8
Far is offline   Reply With Quote
Old   February 28, 2012, 15:58
Duncan Weatherhead
Thanks for that, however my problem occurs at the generate attach state. Where the model in this clip has appeared in design modeller when the user has pressed generate, mine simply returns the error 'unable to attach' and a red exclamation mark replaces the lightening bolt next to the Solidworks icon.
Old   February 29, 2012, 04:20
Ali
Hybrid is on a distinguished road
you must check whether your solidworks version is compatible with the ICEM or not.
You can import as Parasolid or IGES or STEP formats.
I feel version compatibility issue.
Hybrid is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Problems running Smagorinsky Model in XiFoam or dieselFoam MMK OpenFOAM Running, Solving & CFD 1 May 27, 2012 16:31
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 13:23
Sector model mesh problems!! Duan J Q Siemens 4 October 7, 2007 20:05
Convergence problems for 2D model cristion FLUENT 0 October 6, 2005 09:08
