local scour around pier bridge by Eulerian model |
November 19, 2011, 16:39 |
Alireza
Hello everyone,
I am using Eularian granular two phase model (water and sand ). My model is a rectangular flume(3D) with a pier in mid-channel. I'm trying to model water flow over the sand. I should be able patch the sand phase first . This phase is located within a box (domain closed with wall boundary for it) and water flow over it. But I have some problems for solve it. 1- In the material panel i cant see sand. so i selected water for primary phase and air for secondary phase and set granular phase by clicking it in Define->Phases panel and set properties. But i cant sure for it !? I think should define sand as solid phase! not fluid (air or water) 2- for patching, do i set the volume fraction of sand =0 ? 3- If i need define new material for sand, What properties should know of the matter? only granular temperature is sufficient? Im beginner in the Eulerian multiphase flows modeling . My background is restricted to simulation of flow in open channels with VOF. any help from you is very appreciate!! Regards, foroumand |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Puzzling about the "diameter" in Eulerian Model | yuanyuan | FLUENT | 2 | October 22, 2009 08:38 |
Simulation of flow around a circular bridge pier with collar | Dr. Amartya Kumar Bhattacharya | Main CFD Forum | 3 | June 23, 1999 11:48 |
