Home > Forums > Software User Forums > ANSYS
local scour around pier bridge by Eulerian model
Old   November 19, 2011, 16:39
Default local scour around pier bridge by Eulerian model
Alireza
foroumand is on a distinguished road
Hello everyone,
I am using Eularian granular two phase model (water and sand ).
My model is a rectangular flume(3D) with a pier in mid-channel.
I'm trying to model water flow over the sand.
I should be able patch the sand phase first . This phase is located within a box (domain closed with wall boundary for it) and water flow over it.
But I have some problems for solve it.
1- In the material panel i cant see sand. so i selected water for primary phase and air for secondary phase and set granular phase by clicking it in Define->Phases panel and set properties. But i cant sure for it !? I think should define sand as solid phase! not fluid (air or water)
2- for patching, do i set the volume fraction of sand =0 ?
3- If i need define new material for sand, What properties should know of the matter? only granular temperature is sufficient?
Im beginner in the Eulerian multiphase flows modeling . My background is restricted to simulation of flow in open channels with VOF.
any help from you is very appreciate!!
Regards,
foroumand
foroumand is offline   Reply With Quote
Old   February 18, 2013, 05:28
no
abbod is on a distinguished road
Originally Posted by foroumand View Post
Hello everyone,
Regards,
foroumand
Hi Ali
have u already solved ur problem and get the results of the simulation , if yes can u please help me to solve i just started to do this work
regrads
abbod is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Puzzling about the "diameter" in Eulerian Model yuanyuan FLUENT 2 October 22, 2009 08:38
Simulation of flow around a circular bridge pier with collar Dr. Amartya Kumar Bhattacharya Main CFD Forum 3 June 23, 1999 11:48
